ATTN: Volvo experts...Pls Read!!!!
Good morning,
My wife has a 2004 Volvo v70 non turbo. The check engine light came on last week and the car started hesistating. I put the OBD on it and it came up with p0192 Fuel rail. The CEL reset and was fine for a few days then yesterday it came back on and today the car wouldnt start. She got it running then home. Should I replace the Fuel Rail sensor and hope thats the problem? The part is $170 but looks easy to replace. I just dont want to start changing out parts and not fix it. Thanks!!!!!!
P0192 - Fuel Rail Pressure Sensor Circuit Low Voltage
After googling, found this; have you had this recall done?
http://volvospeed.com/vs_forum/index...06-recall-181/
Regarding your first post; that's probably not a bad guess, but it is still a guess.
If it were me, i would attach a fuel pressure gauge to it and drive it; really need to know what the fuel pressure is doing when the engine is acting up...
If you're interested in trying this, make sure you don't take it lightly; this obviously can be dangerous if your attached fuel gauge springs a leak!!!
