BACK IN TIME
Old Mar 8, 2007 | 01:49 PM
martin's Avatar
Default BACK IN TIME
Has anyone experianced thier clock going backwards. when i start the car the clock just goes backwards (time) after a minute or so it will stop obvoiusly the wrong time. It's quite annoying and pointless restting it to the right time as it will start all over again when i switch off.
V70 2003 d5
ta
Old Mar 8, 2007 | 02:58 PM
s80t6schcik's Avatar
Default RE: BACK IN TIME
try disconnecting batt for 15 mins if that does not work let me know ...
Old Mar 8, 2007 | 04:10 PM
martin's Avatar
Thanks for that i'll try it in the morning and get back to you.
Fingers Crossed
Martin
Old Mar 8, 2007 | 04:15 PM
what year is it?
Old Mar 8, 2007 | 04:17 PM
martin's Avatar
2003
Old Mar 8, 2007 | 04:21 PM
is the clock located under temp in the rpm gauge?
Old Mar 8, 2007 | 04:27 PM
martin's Avatar
yes
Old Mar 8, 2007 | 06:13 PM
im not sure on wireing or anything like that if but if the clock is not computer controlled and has its own independent way of keeping time that might be bad but someone would need to look it up in the service book replacing it shouldnt be to hard try battery first...but i think the temp is comp controlled not positive bout this i can look into it more if batt dont fix it keep me informed...
Old Mar 8, 2007 | 09:29 PM
Maybe the button for the clock/trip is going bad.
Old Mar 25, 2007 | 09:02 AM
martin's Avatar
s80t6schick,
Hi apologies for the delay got called away on a job. Did the disconnecting of the battery and it's still the same!!
Hmmm back to the drawing board AAARRRRRGGGGGGHHHHHHHHHH
Old Oct 8, 2007 | 02:39 AM
sigge's Avatar
Hi!
I got the same problem. Volvo V70 2002/2003. The is going backwards...
Old Oct 8, 2007 | 08:35 AM
01_fast_ride's Avatar
I agree with Tech that the button on the clock might be going bad or just stuck in a left-most position. Try jiggling it and rotating it both CW and CCW.
Baythan
Nov 9, 2013 05:21 PM
darkdelta
Dec 22, 2010 07:04 PM
Wicked V6
Sep 23, 2010 07:43 AM
Veronica
Feb 1, 2007 08:50 PM
Uhills
Apr 5, 2005 08:22 PM
