ball joint or control arm replacement
hello all, ive recently found out that the passenger lower ball joint needs to be replaced on my 2000 v70 xc. i cannot find a replacement part anywhere(surprise surprise). it looks like i can only order the control arm assembly, ball joint included. does this mean the task will be easier than if just the ball joint? if anyone has done this replacement, i could use some advice. thank you
