Cabin Air filter?
Old Oct 14, 2005 | 12:54 AM
mickemus66's Avatar
Default Cabin Air filter?
i have an V70 T5 2001, and wonder where is the cabin filter located and how hard is it to change it?
some people say its under the glove apartment, some inside the where the engine is, i dont know???
any tip would be helpful,
thanks.
Old Oct 14, 2005 | 03:28 PM
reg's Avatar
reg
Default RE: Cabin Air filter?
On a c-70 it is under the cowl on the passenger side................... One has to remove appx 3 screws and lift up the plastic shroud and replace it. I would think that is where yours is.
Old Oct 14, 2005 | 10:05 PM
ORIGINAL: mickemus66
thanks.
Yours is under the dash on the passenger side.You have to remove the lower dash panel.Then look for a black cover with 4 torxes screws.Remove the cover and then the filter.
Old Oct 14, 2005 | 10:32 PM
reg's Avatar
reg
not even close was I..............
R.
Old Oct 14, 2005 | 10:42 PM
mickemus66's Avatar
thanks guys, will look in to it tonite.
mickemus
Old Oct 14, 2005 | 10:43 PM
The 2001 and newer are just like the S60 and S80.
The 2000 S/V/C 70's are like yours.The C70 is like that till 2004.
Old Oct 14, 2005 | 11:54 PM
satchmodog's Avatar
Just did mine tonight. Took all of ten minutes. Man was that sucker dirty.
Old Oct 15, 2005 | 11:32 AM
reg's Avatar
reg
I believe that Tech will tell you that changing it will prolong the life of the evaporator in your AC system...............inexpensive maintenance!
R.
Old Oct 15, 2005 | 11:51 AM
ORIGINAL: reg
R.
100% CORRECT!!!!
Old Dec 22, 2005 | 11:35 PM
iceracer's Avatar
While we're at it, where is the cabin filter located on a 98 v70?
Thanks, Terry
Old Dec 23, 2005 | 09:54 PM
ORIGINAL: iceracer
Thanks, Terry
Yours is located under the plastic wiper cowl at the bottom of the windsheild on the left side.
Remove the 2 Torxes screws on the passenger side and lift the panel up and you can slide it out.
Old Dec 24, 2005 | 02:28 PM
iceracer's Avatar
Do I have to remove the wiper arms to get at it?
When you say; " left side" is that as you look at the car from the front or as you're sitting in the drivers seat?
thanks tech.
T.
Old Dec 24, 2005 | 02:44 PM
Sorry on the passenger side. No you don't have to remove the wiper arms.
Just lift the panel and you will see the filter.
Old Jul 27, 2013 | 09:24 PM
JJH's Avatar
JJH
where would the cabin air filter be in a 2000 s40. I bought the filter just don't know where it goes.
Old Jul 28, 2013 | 12:29 AM
JJH's Avatar
JJH
Default Cabin Air FILTER
I just bought a cabin air filter for a 2000 S40 but don't know where it goes or how it is installed....Please Help!
Old Jul 28, 2013 | 05:45 AM
Try Google , lots of answers there.
debargha
Feb 24, 2015 10:46 PM
nigel_miguel
Jan 7, 2012 05:09 PM
bluemagicbus
May 17, 2011 07:18 AM
edahlgren
Oct 21, 2010 06:24 PM
Ahmed
Mar 28, 2008 04:22 PM
