can't get new cv joint back in... tricks?
Well, I'm replacing the drivers front drive shaft and was trying to put the new cv joint in (inside joint first) but can't seem to get it to pop into the tranny.
It's getting stuck on the snap ring... anyone know a trick to get it in there? I hit it with a hammer a few times but no go.
Thanks.
Thanks.
Put a dab of grease on the snapring to hold it, then move it so it's concentric with the shaft. Put the driveshaft on and compress it toward the transmission as far as possible by hand (to take the play out), then tap it with the hammer. Be careful not to damage the driveshaft. Good luck.
ORIGINAL: chopsieze
great idea! is there any grease I should/shouldn't use being it's going into the transmission?
Thanks!
Thanks!
Thanks for the help guys, I got it in... since the ring was slightly bent from trying to jam it in there I just tried to squeeze it back together as much as possible. Then (again since bent a little) I was able to get it to stay centered then carefully slid it into the hole and once I could tell the teeth were lined up gave it a quick shove and got it popped in there.
I think I was just frustrated the night before trying to get it all done but couldn't since it took me over an hour to get the ball joint and control arm separated. I finally realized I needed to push a little harder on the bottom of the rotor, cause then the tension was totally released and it practially fell out.
