Can't get sunroof installed back on rail; bad angle
Old Oct 9, 2009 | 04:38 PM
850forum's Avatar
Default Can't get sunroof installed back on rail; bad angle
The 3M 77 Spray Adhesive I used to re-glue the headliner didn't stick, so now a few years later I did it again.
I removed it per the Bay13 article and
http://www.matthewsvolvosite.com/cha...db27cf745e35b1
Now I am unable to get the sunroof back onto the rail.
First, I have trouble lining it up side to side, so both of the "tabs" fit inside the rails.
When I achieve that, then the tabs are too far to the rear by almost an inch.
I'm trying without success to get the rails in the correct position backwards/forwards so that I can then adjust their upwards angle so that the screw holes are backwards by the inch that I require.
The right rail has some broken plastic down in the guide track area, and sometimes one of the pivoting parts will pop up out of the rail. I can see it, I think, and keep it pushed down with a screwdriver until it passes that point where it pops out.
But I really need some guidance on what the correct position of the rails needs to be, both fore & aft and then how to adjust the upwards angle involving the several independently pivoting arms.
Old Oct 9, 2009 | 07:27 PM
850forum's Avatar
I have managed to force it; used a lever to pry the 2nd hole into alignment on the right. I had to loosen the rearmost screw on the right.
Now the problem seems to be that it binds before going backwards; it does not seem to "dip" correctly before starting to move backwards.
Old Oct 10, 2009 | 09:16 AM
JPN's Avatar
JPN
That symptom is somewhat common.
I hope the attachments can give you some ideas.
Sorry I couldn't help you better.
JPN
Attached Thumbnails Can't get sunroof installed back on rail; bad angle-850-sunroof.jpg   Can't get sunroof installed back on rail; bad angle-850-sunroof-track.jpg
Old Oct 10, 2009 | 09:46 PM
850forum's Avatar
Grrr.. the server won't let me see those images, I keep logging in but it keeps going back to the login page.
Hovering over the image opens a window, but it doesn't show anything but the "?" indicating a bad link.
boarders123
Jun 23, 2012 09:16 PM
chopsieze
Sep 18, 2008 09:08 AM
ludeless
Dec 17, 2005 07:14 PM
