can't remove dipstick
Old Apr 20, 2008 | 08:25 AM
ashley's Avatar
Default can't remove dipstick
Hello,
I have been prompted to these forums due to a fault on my recently purchased V70.
Has anyone come across this problem before?
I have an auto gearbox and the dipstick will not come out, it will rotate right and left but no matter how much i try, it will not come out and i am not exactly a weak person.
Any help you could give me would be much appreciated.
Many thanks.
Old Apr 20, 2008 | 08:35 AM
Default RE: can't remove dipstick
The O-ring seated to the tube.
Sorry to say but BRUTE force is the only way to get it out.
The dipstick won't usually break it will just come out and maybe tear the o-ring.
Old Apr 20, 2008 | 08:47 AM
ashley's Avatar
Many thanks.
I thought that would probbley be the cause but i wanted to check with the experts first.
Now where did i put that sledge hammer
Old Apr 20, 2008 | 09:24 AM
ashley's Avatar
Thanks Tech.
I heated the tube slightly and then used only half the force that i used before and out it popped.
the 'o' seal was to thick so i have fitted a slightly thinner one be it the same diameter.
A quick coat of oil and the problem is solved.
I like these forums
Thanks again
Old Apr 20, 2008 | 10:46 AM
Glad you got it.
k1m2c3
Mar 23, 2010 04:10 PM
cjdunne
Nov 10, 2009 02:08 PM
francis9819
Jan 21, 2009 11:21 PM
01VOLVOS60T5
Dec 24, 2008 09:44 PM
jorhyne
Oct 20, 2007 06:31 PM
