catalytic converter removal
Old Aug 4, 2015 | 10:51 PM
frankiethethumper's Avatar
Default catalytic converter removal
Hello, I have a 2002 Volvo V70 2.4 Turbo that I am being told has a bad catalytic converter. New converter + labor is very expensive. Mechanic/friend offered to eliminate it with a straight pipe to save money as we don't have emissions testing where I live. Curious of the potential mechanical complications or damage to the car (engine, turbo, etc.) that removing it may cause, even if it is done for a short period of time while saving money for a new one. Thank you.
Old Sep 2, 2015 | 10:05 PM
labor for installing a new catalytic converter shouldn't be more than 1 hour of shop time (its only 6 bolts or so...) I've seen prices range from $300 on eBay to $425 for quality brands like Bosal so its not the most expensive repair. I can't imagine possible damage a straight pipe can create - but note where your O2 sensors are on your model - if there's one after the converter you may wind up with a check engine light unless you put in a spacer (google CEL BOSS O2 sensor spacer).
Old Sep 8, 2015 | 10:18 PM
Got it changed for just under $600.00 with a converter off of ebay. Runs good now. Thanks for the input.
J Dubb
Oct 31, 2013 06:02 AM
sferrall
Jun 20, 2012 10:37 AM
cichy1012
Jun 16, 2009 02:12 PM
carlo
May 20, 2005 11:35 PM
carlo
May 11, 2005 04:28 PM
