Cruise control not working
Hi all, right i have just had my cars oil changed by a friend, and since getting the car back my cruise light wont come on, so it dosnt engage.I have checked the fuses, and they all seem okay. everything else in the car works. Where do i look next.
I use the cruise alsmost daily and feel totally lost with out it.
Help!!
Help!!
Try this it ONLYtells you what system has codes won't tell you what they are.
With the car running push in and hold the read button on the end of the turn signal stalk.
Then press the rear foglight button 3 times fast then release the read button. In the display window to the left will will check DTC's in the car. Press the read button to look at each system.
See if there is codes in the following systems.
ECU
TCU
BCM(ABS)
CEM
Check that and let me know.
ECU
TCU
BCM(ABS)
CEM
