Door is locked, but it opens anyway
Old Jan 28, 2010 | 08:53 AM
starsprout's Avatar
Default Door is locked, but it opens anyway
Hi-
I have a 1999 V70 Wagon.
One day I noticed that even when the door is locked, I can open the passenger door from the outside. The lock is in the down position.
Any idea what's causing this and how to repair? Do I need a new part?
Thanks!
Old Jan 28, 2010 | 09:58 AM
cn90's Avatar
Likely Door Actuator, About $130 or so online. Use only Volvo part.
http://www.trademotion.com/splash/in...?siteid=213784
Look under "Front Door", "Lock Hardware".
Or Google for "Volvo 8628224".
http://www.youtube.com/watch?v=LreeVUCemrw
1. Remove INNER Door Panel.
2. The Door Actuator is right there, very easy to replace, just watch the existing setup and replace it.
Do a search and you will find some DIY here or at volvospeed.com.
Old Jan 28, 2010 | 10:17 AM
Sailing_Faith's Avatar
Yup,
Just to add a 'second opinion' the last post is accurate. The lock actuator assemblies are both pricy, and prone to many failures... I had the exact symptoms you describe when I replaced mine on the passenger door... and now need to replace the drivers door too!
Mamedarling
Mar 13, 2013 07:46 AM
jenn
Jun 12, 2011 01:21 PM
StrlngSlvr06
Jan 28, 2010 10:58 PM
StrlngSlvr06
Jan 27, 2010 02:42 PM
ninefour850t
Jul 31, 2007 08:41 PM
