Drive Train Symptoms
Old Feb 18, 2010 | 09:13 AM
goodwinter's Avatar
Default Drive Train Symptoms
I'd like to propose using this thread to solicit specific symptom descriptions of the various drivetrain problems that can occur -- searching the many forums, few have narrowed down exactly what each broken object sounds like or behaves. This would be very helpful as a central reference for future searches.
For example...
Driveshaft center support/bearing. What does it sound like when the rubber piece deteriorates? or the bearings go bad?
Viscous Coupler -- this has been mentioned as going bad frequently on AWDs, but specific symptoms are not described.
Freewheel
general "clunking" sounds -- what specifically is causing the clunk? What is hitting what?
etc.
Old Feb 18, 2010 | 07:47 PM
goodwinter's Avatar
Default Torque Tube mount bushing
The Torque Tube upper arm bushing, where the torque tube is bolted to the undercarriage, fails. Mine split/disappeared, enabling the clunks. Indy mechanic showed me the driveshaft/torque tube movement on the rack while his assistant shifted forward, reverse quickly. It rests on bolt head, then when torque increases, lifts up and bangs into the undercarriage. Rubber bushing prevents this banging. Cheap part, cheap labor.
Photo here...
http://carrepairphotos.shutterfly.com/pictures/9
Xrious
Dec 17, 2011 08:27 PM
memobill
Dec 17, 2010 09:03 PM
bill Mc
Dec 31, 2009 07:43 PM
lhfgracebanet
Mar 27, 2009 04:47 PM
davemoffat
Apr 13, 2008 11:19 AM
