drive train noise
Old Dec 16, 2009 | 09:08 PM
bill Mc's Avatar
Default drive train noise
Bought an '01 S60 this past summer. Now winter & first time in snow. When the wheels started spinning on the ice- snow, a noise started from the front end. A metallic squeel noise...kinda like the noise from a very worn brake pad on the rotor. (checked the brakes, seems like plenty of pads left). Noise continues and is only detectable when on ice'y roads when wheel slippage is happening...otherwise on dry road...no noise.
However, now while driving now on dry roads, there also seems like there is now lots of drag when de-accelerating. I raised the car and all wheels rotate fine. Have not had this drag condition before. STC switch on or off makes no difference. Any ideas...did spinning the tires in the snow cause a transmission issue?
Thanx for any help!
Old Dec 17, 2009 | 08:03 AM
Bender's Avatar
sounds like your abs modual may be screwed up or your pads are REALLY low.
Old Dec 19, 2009 | 10:36 AM
biglipps66's Avatar
I was hoping to find a thread like this.. I had the SAME problem this morning on the way to work. The same noise, everything. I know my pads and rotors are fine though because they were all just replaced. Hopefully someone else chimes in on this as well. Im hoping its a simple silly problem though because I have about 3 weeks left on my warranty if its a serious problem.
Old Dec 19, 2009 | 11:17 AM
biglipps66's Avatar
I found this to be interesting...
https://volvoforums.com/forum/showth...ng+drive+train
I find it hard to believe if it were wheel bearings that I would just now notice it in the snow. Another thread suggested something like water/snow splashing on the belts causing noise.. but doesnt sound like my metal grinding noise. This is an odd one for sure. On the way home from work Im wondering if itll do the same thing again.
Old Dec 19, 2009 | 12:49 PM
biglipps66's Avatar
Breath easy... I found the answer
http://forums.swedespeed.com/zerothread?id=34578
Old Dec 29, 2009 | 02:34 PM
celjock's Avatar
check out my post of Nov 27, 2008. I had a similar problem and it turned out to be releated to the muffler heat shield. In slushy/ snowy weather only it would make a very high squeal when the heat shield would rub against the drive drive train.
Old Dec 31, 2009 | 07:43 PM
Nataku's Avatar
I too have experienced this. Today was the first time, though. On very icey roads when the wheels would just spin. Haven't had any issues with dragging on de-acceleration, though.
Xrious
Dec 17, 2011 08:27 PM
memobill
Dec 17, 2010 09:03 PM
goodwinter
Feb 18, 2010 07:47 PM
lhfgracebanet
Mar 27, 2009 04:47 PM
davemoffat
Apr 13, 2008 11:19 AM
