ECM-9150 error code from PPC reader
Old Mar 21, 2009 | 02:03 AM
mcbalagtas's Avatar
Default ECM-9150 error code from PPC reader
I bought the PPC code reader for my recent xmission codes and it has already paid for itself.
I've been getting a ECM-9150 ( Throttle Unit/Control Valve Inlet) intermittently. There isn't any obvious symptoms...just the warning triangle and Engine Service Required. I suspect this is the ETM right?
I have ALL the service records from the previous owner and found the ETM software upgrade was done at 71k 2yrs ago. If that's true, can I just replace the ETM when it goes bad and is it a DIY job? (I recently did the timing belt and Xmission flush) Is there PM I can do to extend the life of the ETM?
Detailed list of errors for: ECU ECM with code 9150 from PPC's websidte
ECM-9150 Control valve inlet. Signal too high
ECM-9150 Control valve inlet. Signal too low
ECM-9150 Electronic throttle module (ETM), internal fault. Faulty signal
ECM-9150 Throttle unit, internal fault. Faulty signal
ECM-9150 Throttle unit, potentiometer 1. Faulty signal
ECM-9150 Throttle unit, potentiometer 1. Signal too high
ECM-9150 Throttle unit, potentiometer 1. Signal too low
Anyway to isolate the problem to one of the above?
Old Mar 22, 2009 | 08:36 PM
Make sure the vent system is clean.
The car may be under the extended warranty for the etm from Volvo which is 10 years 200,000 miles.
s60-owner
Jun 17, 2015 06:38 AM
dejan_da_dude
Feb 24, 2015 01:17 AM
sms7452
Dec 8, 2010 01:28 PM
mjkoskinen
Oct 30, 2010 02:53 AM
537playing
Aug 18, 2010 09:27 PM
