Electrical Gremlin 2001 V70 Voltage too high
Old Apr 27, 2010 | 10:11 PM
worldbound4now's Avatar
Cool Electrical Gremlin 2001 V70 Voltage too high
If you don't want to read the whole story, skip to the last paragraph for the root question and please provide me with your thoughts and experiences. Thank you!
Car: 2001 V70 with approx 153000 miles
Issues:
SRS light has been on for months. Car has run great.
4/24/2010 - Wife is driving the car to work and receives the "El. system" needs service message with the battery light on. I met her after work and we drove together to an Autozone which was about 5-8 miles away. On that journey, the V70 gained mistook the spring season as our end of December holiday and started setting off lights. First, the chronic SRS message and El. system message. Next I noticed my yellow triangle turn red and saw a brake system failure warning message with the ABS light on the instrument panel activated. Within a few seconds I noticed the pull over safely message and at this time was probably within a mile of the auto parts store. As I looked down, I now noticed all messages gone, the spedometer stuck at "0", my turn signals don't work, and my climate control system has been disabled. The car started to run a little odd.... as if in "W" mode when taking off from a stoplight. Thankfully I was pulling into Autozone within a minute or two more and safely parked the car.
I limp into autozone and they hook up their tester on the non-running car. With a 2.5 amp draw, the voltage drops to 8.5 volts almost immediately. Within a short few minutes, their machine beams out the message "bad battery". Luckily, they had a replacement battery on hand. Unfortunately, it was $170. Out with the old, in with the new, car starts up and runs great. The only residual lights on the warning light cluster is the red battery, and the message center notes the car needs El. system service as well as the chronic SRS light. With a knowledge deficit, I felt this was maybe an error code that only the dealer could clear. I make one short (2.5 miles round trip) to the store later that night and let the car sit until Monday.
On Monday, I go out to the car to head to the gym and low and behold, all my error codes and lights are off. Painfully so, I realized that everything was off. Key in the ignition and not a blip of power. No dome light, no dash response, nada, zilch. (insert many profane words that I barked out as I began pulling out tools/testers). Dead. Battery posts are spotless. Battery ground is firm to the battery and to the interior of the car. Positive lead on battery is connected firmly.
When my wife got home, I headed to the auto parts store where I purchased a cheapie 1.5 amp battery charger and a digital multimeter ($50 total... cheaper than an hour at the local shop). Initial multimeter voltage across battery posts was not reading. I hooked up jumper cables from my running car and, after a few minutes pause, the V70 fired right up. Voltage at idle 13.1. Voltage at 2,000rpm was 13.8. Sounds like I may have purchased a dead battery. I put it on the weenie trickle charger for an overnight proverbial electrical soaking.
4/27/2010 I head out this morning greeted with the "abort" light flashing on my charger. Key in the keyhole results in silence and darkness. )(*^(*&%$!! I pulled the battery and headed back to Autozone where they replace my battery after testing failed. No cost, easy warranty swap.
My optimism is rising. Maybe that Duralast battery was crap. Maybe? Out of fear of two strikes in a row, I have the Autozone rep connect the brand new replacement battery to their tester. It passes their testing sequence. Phew.
I get back home and install the new battery. Battery disconnected shows 12.8 volts. Yippee... Battery installed, dome lights come. YES!!!
Key in the keyhole and advanced forward.... SUHWEEEET.... the dash lights up like always. Hit the starter and she fires right up. But wait... a new message and odd behaviors. Now the El. voltage "high" message is showing, a brake system failure light is on, and the car is cycling through high draw devices. I hear the engine fan cycling on and off, the climate control fan cycling on and off, and see the rear window defrost indicator flashing at me on and of. My big gray brick seems to be doing everything she can to soak up the extra voltage and not fry her sensitive circuitry.
A quick run back to the battery reveals voltage variables from 13.7-18.6 volts as these devices cycle on and off. HOLY CARP. The charging system is really ramped up. I run forward to turn the car off. Checked battery voltage with car off... 12.6 volts. Disconnect the ground, let the car sit for 11 minutes (I watched the clock and drank a beer), and reconnected the ground.
Same issue. My voltage is too high, and my car thinks it's Christmas again
Now, I've wrenched a lot as a child and realize that most alternators have/had a regulator built on or inside of them which does as it's namesake states... regulates the charge. On the 2001 V70, is the voltage output from the alternator controlled by the alternator and monitored by a central electronic module of some sorts, or is there a central brain that actually controls the alternator output? I'm tempted to head out and purchase a re-manufactured alternator, but don't want to throw my money away just to find out that this car regulates its charging system from a higher level computer somewhere outside of the alternator assembly.
Thank you for any advice or information you may have to aid me shaking down this electrical problem!
worldbound4now
Old Apr 27, 2010 | 10:30 PM
You can purchase and replace the voltage regulator only.
Not sure exactly who sells only the regulator but it can be replaced.
Old Apr 27, 2010 | 11:06 PM
Default voltage regulator
I found regulators available here http://www.partsgeek.com/gbproducts/...ek+Google+Base but don't know which one to purchase. Is the OEM alternator on the non-turbo V70 120 amp or 140/160 amp?
Thanks again!
nevermind... i see the part numbers are the same.
Old Apr 30, 2010 | 03:18 PM
Thumbs up New regulator fixed many gremlins
Thank you, Tech, for the advice. This was by far one of the easier jobs that I've done on my V70. I pulled the alternator, removed the black plastic cover on the rear of the alternator, removed the old regulator and then reassembled with the new. The most difficult part of the entire job was getting the serpentine belt back on in the correct order.
Just a side note, the original, bad regulator that I removed from the car was Bosch #F00M145229 and it was replaced by Bosch #F00M145369. It was an easy, direct fit replacement and I now have consistent charging voltage high 13's when at idle with minimal load (exerior lights on only) to high 12's with A/C on full, heated seats on high, radio on, flashers flashing, and high beams on headlights.
All of my warning lights are off except for my chronic friendly SRS light and I also blew out my dim level headlight bulbs when I was having the high voltage error, so that message is also present.
Despite my status on this forum, I'm no longer helpless.
worldbound4now
edit: BTW, the regulator was just under $60, so this was not only a relatively easy repair, it was also cheap!
Old Apr 30, 2010 | 09:52 PM
Glad it all went well for you!
Old Apr 10, 2015 | 06:03 AM
Pedman's Avatar
Did the new alternator voltage regulator fix the problem?
Old Apr 15, 2015 | 05:14 PM
onto the SRS warning problem - you should be able to get some codes to see which area the car "thinks" is in trouble. A likely cause is the under seat connectors - somebody may have kicked the wire etc, although my local indy was telling me he fixed one once where a mouse got inside and chewed some up... For me it turned out I had to replace one of the airbags (lower side on my S40) but the codes pointed where to look.
WickedChristian
Mar 22, 2015 02:04 AM
Fogducker
Feb 14, 2014 11:35 AM
pharmerbill78
Jun 16, 2009 11:20 PM
dekethefreak
Dec 17, 2008 04:15 AM
jfikentscher
Feb 28, 2006 10:19 PM
