Electrical problem lights and windows
Old Oct 5, 2005 | 01:55 AM
PennStateFan33's Avatar
Default Electrical problem lights and windows
I have a 1999 V70. Have owned the car for 2 years and have been very happy with it. Two recent problems that I was hoping someone had experience fixing. Two separate electrical events. The first (about two weeks ago) was the loss of headlights and turn signals while driving. Stopped, turned the car off, turned back on and the lights returned. That problem hasn't returned. The second happened last week when the power window motor stopped working, all windows are affected. When attempting to put the windows down the lights, dashboard and head lights flicker. Any ideas where to start? Are they related?
Thanks,
Tim
Old Oct 5, 2005 | 09:37 PM
Default RE: Electrical problem lights and windows
I would start with wiggling the ignition switch and see if it does it again or fixes it when it is happening.
Most of the time it is a bad electrical part of the ignition switch.
Old Oct 11, 2005 | 07:01 PM
Tech
Thanks, will try the ignition if the lights blink again.
New information on the power window problem: the little puffs of smoke coming from the window up/down button signaled a problem in the door. Even I can recognize that smoke is a problem in the car.
Thanks,
Tim
Old Oct 11, 2005 | 09:21 PM
For the windows you will need to replace the Master window switch.
Hunter Thomas
May 24, 2014 10:49 AM
mjohnny
Mar 18, 2013 02:35 PM
Hermes
Jul 15, 2010 09:24 AM
vnole
Nov 6, 2009 10:18 AM
bryanbloom
Mar 17, 2007 06:22 PM
