Engine noise...
Ok, so I just posted about my window not functioning properly. Whatever, temporary fix. Just don't have the luxury of opening my windows.
Now here comes the bad news. I went into my place with my car running to recharge the battery and I came back out to a horrific noise. Ticking. From the engine. From the valvetrain, I think. And yes it increases as my rpms increase. The car has 147K on it but this is ridiculous. All of a sudden there's too much clearance between the cam and valve? If this is something else please fill me in. If this is a mechanical clearance issue, please givemea gun. Apparently I opened up a can of worms just trying to get my window to go back up. |
RE: Engine noise...
It is pretty common on these cars.
The o-rings between the oil pan and the engine go bad. That causes a drop in oil pressure. I have a post about replacing them in the top of the S70 section. |
RE: Engine noise...
Thanks for the help. However.... upon starting my V70 this am, the ticking was there. After I started it and let it run for about 10 minutes and started driving to work the noise went away. I got out of my car when I got to work, bout a 20 min drive, quiet as a mouse. No more noise, for now.
Weird.... |
RE: Engine noise...
Have you noticed an oil light flickering on the dash?
RE: Engine noise...
ORIGINAL: burnferris Thanks for the help. However.... upon starting my V70 this am, the ticking was there. After I started it and let it run for about 10 minutes and started driving to work the noise went away. I got out of my car when I got to work, bout a 20 min drive, quiet as a mouse. No more noise, for now. Weird.... |
RE: Engine noise...
No I haven't seen any warning lights on my dash, especially the oil light. I completely understand the fact that seals, o-rings, etc. wear out over time and do need replacing. But there is no noise or lights or any other indication in a lack of oil pressure. There appears to be plenty of oil splashing around when I remove the oil fil cap with the engine idling. Thanks for all the help, I do appreciate it greatly. And if you feel the need to fill me in on anything else let me know.
RE: Engine noise...
I would keep an ear on it.
It is only going to get worse. |
