Engine noise...
Old Oct 30, 2007 | 08:18 PM
burnferris's Avatar
Default Engine noise...
Ok, so I just posted about my window not functioning properly. Whatever, temporary fix. Just don't have the luxury of opening my windows.
Now here comes the bad news. I went into my place with my car running to recharge the battery and I came back out to a horrific noise.
Ticking. From the engine. From the valvetrain, I think.
And yes it increases as my rpms increase. The car has 147K on it but this is ridiculous. All of a sudden there's too much clearance between the cam and valve?
If this is something else please fill me in. If this is a mechanical clearance issue, please givemea gun.
Apparently I opened up a can of worms just trying to get my window to go back up.
Old Oct 30, 2007 | 09:28 PM
Default RE: Engine noise...
It is pretty common on these cars.
The o-rings between the oil pan and the engine go bad. That causes a drop in oil pressure.
I have a post about replacing them in the top of the S70 section.
Old Oct 31, 2007 | 09:51 AM
burnferris's Avatar
Thanks for the help. However.... upon starting my V70 this am, the ticking was there. After I started it and let it run for about 10 minutes and started driving to work the noise went away. I got out of my car when I got to work, bout a 20 min drive, quiet as a mouse. No more noise, for now.
Weird....
Old Oct 31, 2007 | 10:13 PM
Volvocars's Avatar
Have you noticed an oil light flickering on the dash?
Old Oct 31, 2007 | 11:36 PM
Rickc10ny's Avatar
ORIGINAL: burnferris
Weird....
Don't let the avoidance of 2 1/2 hours of labor and $100 in parts turn into a $4000+ engine replacement, Little problems have a bad habit of turning into big problems on these cars if not repaired promptly.
Old Nov 1, 2007 | 09:25 AM
burnferris's Avatar
No I haven't seen any warning lights on my dash, especially the oil light. I completely understand the fact that seals, o-rings, etc. wear out over time and do need replacing. But there is no noise or lights or any other indication in a lack of oil pressure. There appears to be plenty of oil splashing around when I remove the oil fil cap with the engine idling. Thanks for all the help, I do appreciate it greatly. And if you feel the need to fill me in on anything else let me know.
Old Nov 1, 2007 | 06:45 PM
I would keep an ear on it.
It is only going to get worse.
Rafiolo
Jan 1, 2012 02:34 PM
chimmychong
Apr 2, 2008 08:39 AM
ludeless
Aug 28, 2007 07:14 PM
pitchpipe
Nov 7, 2005 08:50 PM
sick_boy93
Apr 4, 2005 09:42 PM
