First Posting - V70 Died !
Old Feb 13, 2013 | 08:51 AM
j-canada's Avatar
Default First Posting - V70 Died !
Good Morning - An owner of many many Volvos over the years the technology is starting to beat me!
Volvo V70 2.5t 2005
Bought 3 days ago secondhand - 122,000km
Did I put the wrong fuel in it ?
87 octaine regular gas - should it have 89 ?
Driving along wonderful - topped it up with gas travelled 400km and then "Reduced Engine Performance" and the warning triangle displayed. The car essentially stopped.
I switched it off swore and restarted it and all seemed fine - Then it did it again 20km later.
I've looked at draining the fuel but cant seem to get a syphon tube into the tank.
Any input gratfully received - And How do I reset the messages? - The trip meter, Ignition position one then two doesn't appear to work.
Old Feb 13, 2013 | 08:28 PM
ssicarman's Avatar
Unless you got bad fuel putting in 87 instead of premium should not cause your problems, especially after 400km.
You will need to get the codes read to see what is setting them.
Old Feb 13, 2013 | 08:29 PM
gdog's Avatar
Sounds like you need to have it scanned for fault codes and go from there.
Read the owner's manual (online if you don't have it); pretty sure they recommend 89 octane or better but it should run fine (but with slightly less performance) on regular.
Old Feb 14, 2013 | 08:15 AM
j-canada's Avatar
I've travelled a further 200km and it seems to run sweet
How can I get the messages reset ond the warning triangle extinguished?
Is this something I can do myself?
Old Feb 14, 2013 | 12:53 PM
Maybe not. On older cars you can disconnect the neg battery cable for 30+ minutes and when you hook it back up, all codes are lost.
OoaudreyoO
Feb 12, 2019 09:57 PM
SLOjohn
Oct 12, 2014 09:15 AM
steve_o
Jan 20, 2012 07:52 AM
pgsharpe
Feb 15, 2011 01:49 PM
gilber33
Aug 26, 2009 09:46 PM
