headlight washer ?
Old Oct 9, 2008 | 07:10 PM
rtm's Avatar
rtm
Default headlight washer ?
I noticed that when I operate my windshield washer, the junction that joins the two headlight washers together has a relief hole in it.
although the hoses aren't clogged, the fluid squirts from this hole, rather than at the headlights themselves.
is this part neccessary ? can I delete it and install a "t" fitting?
Old Oct 10, 2008 | 07:33 AM
Default RE: headlight washer ?
Yes you can delete the factory one. When the fluid come out the hole like that it means the diaphram inside is bad.
They put the valves in there to help hold pressure. The only way it will affect it at all is it will take a few seconds longer for the fluid to reach the wiper arms to come out.
Old Oct 10, 2008 | 05:44 PM
rtm's Avatar
rtm
thanx 4 reply,
on my wife's '99 the little tab that holds the wiper arm from dropping below the headlight is missing
is there a part # for that / is it hard to replace?
Old Oct 10, 2008 | 05:52 PM
I will try to to get the part # for you. But you will have to remove the headlight to replace it.
Old Oct 10, 2008 | 06:09 PM
rtm's Avatar
rtm
thanx again
Old Oct 10, 2008 | 07:13 PM
8628246 That is the part# for it.
Old Jul 15, 2009 | 01:03 PM
lglitt's Avatar
Default 850Turbo 1994 t-valve location
The t-valve for the headlight washers seems to be defective since the right side washer gets much more fluid pressure than the left side. I have the replacement part but how exactly do you access the t-valve? Thanks from Canada!
jbru
Jul 4, 2012 08:10 PM
VolvoSilva
Sep 12, 2011 08:32 PM
RK Volvo
Apr 28, 2010 10:14 PM
nclair
Oct 6, 2009 10:16 AM
dinopix
Jul 27, 2006 11:57 PM
