Heater core Leak? 99 V70 FWD
Old Oct 10, 2006 | 09:06 AM
hubmachine's Avatar
Default Heater core Leak? 99 V70 FWD
the wifes care may have a leaky heater core?
symptoms are as follows:
when heat is on, right side of wind shield gets foggy. slight smell of ethyline glycol.
is this the heater core, or some other part of the heater system. water does not condense on the left side of wind shield.
many thanks
cliff
Old Oct 10, 2006 | 09:47 PM
Default RE: Heater core Leak? 99 V70 FWD
I would say it is leaking.(Heater core)
Old Oct 11, 2006 | 10:30 AM
hubmachine's Avatar
ok so what is the easiest way to get to it. do i have to pull the dash? is so, are there any online directions on the best way to go about this?
many thanks
cliff
Old Oct 11, 2006 | 08:40 PM
No you don't have to pull the dash.
I saw a write up about it somewhere but forget.
You will have to pull the lower dash panels,Center console, then the bottom of the Heater box and swap out the cores.
Old Oct 11, 2006 | 10:20 PM
hubmachine's Avatar
if you happen to recall where you saw the writeup i would appreciate hearing...
do i have to drain the radiator at all to do this? anything to watch out for? tips?
really do appreciate the help you provide on this site.
cliff
Old Oct 11, 2006 | 10:31 PM
You don't have to drain the Radiator. Youi just remove the heater hoses and point up and you are fine.
I normally don't like to post links to other forums but haven't been able to make the post myself.
The only difference between the one in the link and yours is that you will have to remove your gas pedal and Base from the floor. Which is 5 screws total.
http://volvospeed.com/vs_forum/index...howtopic=35445
ycartf
May 6, 2013 11:19 AM
nick7734
Sep 6, 2010 11:19 PM
uncle
Sep 13, 2009 04:19 PM
jimduke
May 24, 2009 10:55 AM
greystoke
Apr 30, 2008 08:44 AM
