help engine problem
Old Jul 15, 2011 | 03:12 PM
steve-v70's Avatar
Default help engine problem
hi im sorry im new to forums i have just getting a volvo v70 t5 and on idle there is a tapping noise from the top end of the engine it seems to get worse as the engine warms up help please is this serious
thank you
Old Jul 17, 2011 | 02:30 PM
Hi Steve:
I already answered this in the S70 section. Hopefylly you will not double post to much in the future.
  1. Is it tapping or clicking or knocking?
  2. How loud is the sound?
  3. What year car do you have?
  4. How many miles does it have?
  5. Where did you get it from?
  6. Do you know the service history?
  7. Is there oil in the motor?
  8. When was the last time it was changed?
  9. When was the last timing belt done?
  10. Is there any teeth missing from the timing belt?
  11. Has the motor been replaced?
  12. Do you have any service history?
It is normal for Volvo's to tap a little when first started, especially on cars that have been sitting for a long time. It should go away after a few minutes, 10 max. If it's tapping or clicking longer than that, you likely have a stuck or sticky valve. You may have to remove the intake and spray some valve cleaner in the ports. You can also try to run some Lucas fuel injector cleaner in the gas tank, I believe they claim that it also cleans the valves.
mtyson0440
Mar 12, 2010 07:52 PM
james_caza
Mar 8, 2010 02:54 PM
kusanagiz
Aug 21, 2008 11:35 AM
markjenross
Nov 7, 2007 08:02 PM
