Horn Dead!?
Old 11-08-2009 | 06:22 AM
mikeori's Avatar
Default Horn Dead!?
The horns on my 98 V70 recently died - fuse is good, but I get no voltage at either horn when the pad is pushed. Any thoughts on common problem areas, ie. relay, contact switch, or ? thanks
Old 11-09-2009 | 12:31 AM
gdog's Avatar
Did you ck for 12V at the Horn Fuse?
Typically +12V pwr flows from the fuse to the horns (in parallel) and horn button/switch completes the ground side of the circuit.
In other words if you have pwr at the fuse but not at pwr (+) side of the horns, then you have an open in the harness somewhere.
I would double ck the fuse; make sure you have 12V (referenced to ground) on both sides of the fuse.
BigAdam
08-24-2008 03:18 AM
abelsa
07-11-2005 01:59 PM
tech
11-28-2004 12:03 PM
jersey girl
09-24-2004 12:37 AM
CeeElle
02-17-2004 05:41 PM
Quick Reply: Horn Dead!?
