Idles w/ MAF disconnected, but not when connected
Old Jul 13, 2012 | 02:58 PM
VTBricked's Avatar
Default Idles w/ MAF disconnected, but not when connected
'98 V70 Turbo - swapped a complete subframe engine/trans FWD into AWD. Implant was known functional engine/drivetrain.
The engine swap is complete and it took a while before I had fuel in the injectors to get it started. But it did not idle. At all. I could keep it running by feathering the pedal.
I swapped the ECU and TCU thinking it had something to do with FWD and AWD units. But I don't think there is a difference - at least w/ '98 70 series.
I found an injector connector no fully seated, but seating it gave no improvement.
I looked for vacuum leaks and found none. It idled like it had a massive one.
I swapped and cleaned a MAF with no improvement.
Finally I simply disconnected the MAF. Now it idles, a little rough, and with an occasional pop (detonation?) coming from the intake.
I have another MAF I can swap in, but would appreciate any answers to these questions:
1) What causes detonation in the intake manifold?
2) Why would it idle better w/o MAF than with it? (Is the idle control valve that good at its job? At the least I know it works well!)
Old Jul 16, 2012 | 07:32 PM
VTBricked's Avatar
Default Intake manifold gasket leaking - suspected problem
I've spent a few hours looking, fiddling, thinking.
The super crappy idle really seems like a huge vacuum leak. So I checked all the vacuum lines. There aren't that many. I found one with a marginal seal and put a clamp on it. I found a small line disconnected. Neither made a difference.
It was also seemed hard to believe I had 2 MAFs bad from 2 previously running (well) cars.
Furthermore, when I put it in gear and moved back/forth in the driveway, the brakes barely worked...because there was no vacuum!
So I turned my attention to the intake manifold. I found a few bolts not as tight as I like. The detonation in the intake stopped. The idle wasn't much improved, but the brakes were now getting some vacuum.
Tomorrow I will remove the intake manifold and reseal the gasket. I really think (and hope) that is my problem!
Old Jul 19, 2012 | 06:12 PM
VTBricked's Avatar
Cause of problem discovered and remedied. In a moment of careless/thoughtless (not sure which) work, I caught the sheet metal bracket between the manifold and the head. The bracket should be on the outside.
So I'm relieved I found the root cause, but confess some embarassment at my gaff.
Now the car runs awesome! I look forward to a longer ride when I can get into the boost a little.
PAVolvo850
Jul 7, 2014 04:25 AM
daviddudleyca
Jul 2, 2014 12:11 AM
enigmis
May 11, 2014 11:32 PM
pagragg@pacbell.net
2001-2013 model year XC70
Nov 20, 2012 02:37 PM
winston901
Nov 23, 2011 12:09 AM
