Internal temp problem
Old Apr 7, 2008 | 02:25 PM
v70dave's Avatar
Default Internal temp problem
I have a 2000 W Reg SE I have a problem with the temperature in the cab it does not seem to be able to keep the desired temperature set on the controls is there a sensor that monitors etc is this a common problem ?
Old Apr 7, 2008 | 04:55 PM
billofdurham's Avatar
Default RE: Internal temp problem
If the car is fitted with the Electronic Climate Control system then there is a passenger compartment temperature sensor. It sits behind a louvred panel on the dash,to the left of the ECC panel.
To get to it:
Ignition off.
Remove the radio.
Put your hand through the radio compartment and push out the ECC module.
Now put your hand through the ECC module opening and push out the switch next to the louvred panel.
Again working through the ECC module opening press together the catches holding the temp sensor in place and pull it backwards. Note the position of the sensor before you remove it.
Disconnect the sensor.
Refitting is a reversal of the above.
You will need to check if any diagnostic trouble codes have been stored during the repair work.
Old Apr 9, 2008 | 01:48 PM
v70dave's Avatar
Is this procedure for the mk 2 v70 mine is a year 2000 mk 2thanks for the help so far.
DJ1040
Aug 8, 2010 02:23 PM
northrup
Aug 9, 2009 03:01 AM
wolfman75
Jun 24, 2008 07:56 PM
sunnymaniaus
Feb 28, 2006 09:29 PM
brickhead
Sep 24, 2004 12:29 AM
