-   Volvo V70 (https://volvoforums.com/forum/volvo-v70-13/)
-   -   maple syrup smell from A/C (https://volvoforums.com/forum/volvo-v70-13/maple-syrup-smell-c-13949/)
98T5 Sep 23, 2007 01:19 PM
98 T5 turbo with 114,000 miles, located in the USA.
just noticed a funny syrup smell yesterday from the A/C as it blew cold air..
any info is appreciated. thanks.
b5254t Sep 23, 2007 04:20 PM
RE: maple syrup smell from A/C
Check for coolant leaks it sounds like a leaking heater core. pull back the carpet on drivers side and see if you can see it leaking.
tech Sep 23, 2007 05:24 PM
ORIGINAL: b5254t
+1
98T5 Sep 23, 2007 10:15 PM
I checked behind the carpet by the accelarator and nothing is leaking under there. what's my next move?
thanks
b5254t Sep 24, 2007 06:54 AM
pressurize the coolant system and see if it holds pressure if it does not it is leaking somewhere check your coolant level is it going down any? Check your water pump any cracked hoses, radiator,hoses going through firewall to the heater core. You did not have any other work done to the car recently that may have caused a leak have you?
98T5 Jan 21, 2008 10:03 AM
ORIGINAL: b5254t
I checked the hoses, but I will double and triple check them again today. no work done recently in the engine bay to cause a leak. however, I did buy a new resevoir cap since it was cracked and added some anti-freeze/coolant, but that was months ago.
I will go out here and do a thorough check for leaks all over the engine bay just to be sure.
white out Jan 21, 2008 12:23 PM
Check around the cap to see if it is leaking.
Nick
jks2 Jan 21, 2008 02:27 PM
If you can't find the leak, I suggest a tall stack of buckwheat pancakes.:D Seriously, do you notice a dampness in the carpet? It could be a small leak that is being soaked up before you can see it.
98T5 Jan 21, 2008 09:02 PM
ORIGINAL: jks2
lol...I almost broke out the Biscuits this morning it smelled so good...
Rickc10ny Jan 23, 2008 11:07 AM
maybe you have a Vermont car? :D
