Need steering parts
Old Sep 24, 2021 | 10:09 AM
skoo2's Avatar
Default Need steering parts
Hello - per my mechanic I need a new locking cylinder and ignition starter for my 2002 XC. Is there a 'go to' parts place that is recommended? I have tried the dealer. That's Plan B. Thanks!
Old Sep 24, 2021 | 12:07 PM
Dingus's Avatar
fcpeuro has lifetime warranty on all items
IPDUSA.com
Rockauto for economic choices
Old Sep 24, 2021 | 12:39 PM
Are you talking about the steering column lock? The part you put the key in and turn to start the car? Those do fail are won't turn all the way to the start position.Is that your problem? the key won't turn far enough to start the car? If you purchase and install a used steering column lock - the different key will not start your car - and you will need to spend a couple of hundred more dollars to program your car to accept the signal from the new/used key.
If so the solution is to order a new steering column lock from a dealer using your VIN. A new one will be manufactured and your existing key will fit and operate it.
What is an "ignition starter"? The ignition switch that bolts to the steering column lock?
Old Sep 24, 2021 | 03:40 PM
skoo2's Avatar
Oops - yes. Switch.
Old Sep 24, 2021 | 03:46 PM
skoo2's Avatar
Thank you!
Old Sep 24, 2021 | 04:29 PM
Oops - yes. Switch.
Are you replacing the steering column lock because it won't turn far enough to start the car? If so the only way (unfortunately) to do this is buy one from a Volvo dealer using your VIN - you will be able to use your old key.
You probably don't need a new ignition switch, never have had to replace one (in that year range, older cars many times)
And hopefully you understand you can remove the ignition switch and use a screwdriver to turn on and start the car. (but not really drive-able very far because the windows and other stuff won't work)
Old Sep 24, 2021 | 04:44 PM
skoo2's Avatar
Voluparts shows on its website, it can supply a cylinder that comes pre-keyed to your car, so doesn't require any software download. Hadn't heard that or seen that site before.
Old Sep 24, 2021 | 04:45 PM
skoo2's Avatar
And, yes, the key won't turn far enough to start the car.
Old Sep 24, 2021 | 05:58 PM
No NEW or used steering column lock/cylinder requires a software download. It is simply the mechanical part you put the key in. A software download is needed to tell the car to accept a signal from the chip in a NEW or different key you want to use.
Voluparts is in Atlanta where I live - I have known Bill, the owner since 1974. If you ask him he might claim he taught me how to fix cars - and part of that is true. I took his place at a shop back then.
That said Voluparts is a good source of many Volvo parts at a reasonable price.
What Voluparts will do - if you place an order for a steering lock, they will get payment (volvo won't let you return them) and your VIN. Then THEY will order a column lock from Volvo and ship it to you a few days later after they get it from the local dealer.. The dealer they use is the same one I've used for years. Walt and John work there.
A very good thing about Voluparts is they might sell Volvo factory parts at 10% off list price. Many dealers sell for only list or list + So if the shipping is less than 10% of the part you can save a little buying from Voluparts.
And don't buy an ignition switch - you don't need it! ( i've replaced at least 100 steering column locks and 0 ignition switches of that part number, earlier cars did have problems with the accessory position not working)
Old Sep 24, 2021 | 06:24 PM
skoo2's Avatar
Very cool! I appreciate all of the information! That will save me money and aggravation! Many thanks!!
Old Sep 25, 2021 | 06:11 PM
Kaza123's Avatar
Hi. if need parts you can contact our locksmiths we have the best volvo parts with cheap prices. https://www.autoprolocksmith.co.uk/c...cement-london/
osteen
Aug 6, 2016 10:23 AM
chicago1234
Jan 23, 2016 06:41 PM
chewe
Mar 13, 2014 06:36 AM
Gorm
Mar 3, 2008 07:33 AM
cbevis
May 17, 2006 01:53 AM
