Newbie here! Hello to all, and a question...
Old Nov 3, 2006 | 01:45 PM
PFUND28's Avatar
Default Newbie here! Hello to all, and a question...
Hello everyone! Just bought a 99 V70 5 speed non turbo and I have a question..... drove it home from Oklahoma to Michigan 1000 miles and drove great. The car has 102 K on it. It has 2 open recalls - ETS and headlight switch. Well, I get it home pull in the driveway, and you'd think I'm driving a diesel!!! There is one heck of a top - end rattle that is LOUD!! Arrrrg!! It gets worse as you give it gas. I will have it at the dealer on Tuesday for the recall but does anyone have any ideas? Did I blow it up? The oil is fine, a little over half on the stick, never got hot while I was driving it, of course when I bought it it was as quiet as a church mouse. any help or suggestions is appreciated!
Thanks Bob
Old Nov 3, 2006 | 10:17 PM
Default RE: Newbie here! Hello to all, and a question...
I am about 90% sure you have bad oil Pan o-rings.
When the oil gets hot and thin with the bad o-rings some oil flow is limited.
Old Nov 4, 2006 | 11:47 AM
PFUND28's Avatar
Wow, that would make the engine knock? Interesting, now it knocks when ever it wants. I pulled up to a store and left it running it's knocking away, come back out and it's earily quiet again..... also thanks so much for the reply!
Bob
Old Nov 4, 2006 | 12:04 PM
Your Welcome but it should be more of a tapping noise than a knocking noise correct?
Old Nov 4, 2006 | 12:10 PM
PFUND28's Avatar
I guess it's tapping but LOUD tapping. It seems to be coming from up top not down low like a rod bearing....
Old Nov 4, 2006 | 12:14 PM
Yes then it is the lifters.
If you want to see whats involved in replacing them I made a post about replacing them in the top of the V70 section. If it is not there look in the S80 section.
Old Nov 4, 2006 | 12:21 PM
PFUND28's Avatar
I wonder why they would be loud sometimes and quiet other times? Am I hurting this car if I still drive it?
Thanks again!
Bob
Old Nov 4, 2006 | 12:25 PM
Not sure why either but it does that.
You might be hurting it slightly.
Lack of oil pressure will wear quicker.
Scuba Jim
North East
May 26, 2024 11:29 AM
volvo745newbie
Jul 15, 2015 04:55 AM
Robert Carter
Jun 27, 2014 10:39 PM
techmonster
Aug 3, 2012 03:27 PM
chrisbridges
Feb 4, 2009 10:09 AM
