noise in front end
Old Jan 8, 2013 | 10:39 AM
lmarcous's Avatar
Default noise in front end
what are the possible causes of a rubbing sound in the front end that speeds up when accelerating ?
Old Jan 8, 2013 | 11:02 PM
gdog's Avatar
Well w/o any more background info or a vid w/sound link, uh, any responses are going to be wild-***-guesses (WAGs) so...
Have you done brakes lately or any other work that may have something to do with it?
Old Jan 9, 2013 | 08:20 AM
lmarcous's Avatar
I had front brake rotors, pads and the left front control arm replaced in March 2012.
The work was not done by a Volvo dealer but by the independent tire shop where I buy my tires.
The noise starts at about 20mph and sounds like a chugging locomotive.
any suggestions are appreciated !
thanks!
Old Feb 9, 2013 | 09:58 PM
flowerpower's Avatar
Default Front End Noise
I'm having a similiar issue with my '89245.....and I have had ALOT of work done chasing this roaring noise that getslouder as I accelerate, and stays at that level until I decelerate. In the pastyear, I've had the following work done: BOTH U-JOINTS REPLACED; VALVE COVERGASKET/INTAKE MANIFOLD GASKET; ENGINE MOUNTS; RIGHT AND LEFT LOWER BALL JOINTS;REPACK WHEEL BEARINGS; REPLACE FRONT WHEEL BEARINGS; RACK AND PINION ASSEMBLY;NEW TIRES AND FRONT END ALIGNMENT. Still, that infernal noise continues. Ido know that the tires replaced had abnormal wear patterns, indicating that itIS a front end issue. But, still, no one has been able to fix it. Any ideas?
Old Feb 10, 2013 | 05:24 AM
As GDog stated, post a video somewhere and link it back here.
Old Feb 11, 2013 | 07:06 AM
lmarcous's Avatar
Issue solved ! It was the wheel bearing. Replaced front drivers side wheel bearing and the noise stopped.
Wing0
Dec 13, 2013 02:39 PM
scartydog
Jun 23, 2006 05:25 PM
Virginia Girl
Jun 14, 2006 10:42 AM
cbatterman
May 10, 2006 12:00 AM
ZIGZAG
Mar 17, 2006 09:34 PM
