noise when gas pedal is applied in drive
Old Jul 19, 2012 | 08:26 PM
jesbarber's Avatar
Default noise when gas pedal is applied in drive
last week after driving my 04 v70 for about 1/2 hour a noise began when I applied the gas pedal. I took the car in and was told that the catalytic converter was bad and that the ceramic casing was cracked and that this is where the noise was coming from. They want $1500.00 to replace the catalytic converter. Is this a good price?
thanks
Jesse
Old Jul 20, 2012 | 12:13 AM
forsyther's Avatar
Default Hi
I think that it is ok, you should get it changed i.e. you should get you catalytic converter replaced. Catalytic converters are of price $200 and rest it is its service charges. You can ask at some other shops also about their service charges.
Old Jul 20, 2012 | 10:30 AM
VTBricked's Avatar
You should expect between $800 and 1200. The converter will be between 400 and 800. The labor will be less for non-turbo and front wheel drive.
Tell them you want the old catalytic converter. You can get between $50 and $75 at a metal recycling center.
Old Jul 20, 2012 | 11:00 AM
jesbarber's Avatar
thanks
Jesse
Thank you
I'm having another repair shop look at the car right now.
Old Jul 20, 2012 | 11:02 AM
jesbarber's Avatar
Thank you your help
Jesse
Old Jul 20, 2012 | 11:05 AM
jesbarber's Avatar
I will ask for the old converter back.
Thank you for you answer and tip
Jesse
ljarch
Aug 8, 2011 10:01 PM
mramend
Apr 19, 2011 11:52 PM
Vgatorgirl
Jul 23, 2010 09:27 AM
Edinburgher
Feb 21, 2008 07:22 PM
nsmock
Apr 22, 2005 07:37 PM
