Blinker lights stop working when brakes applied
Old Apr 21, 2005 | 08:58 PM
nsmock's Avatar
Default Blinker lights stop working when brakes applied
When my lights are on, the blinkers blink very fast then when I apply the brakes they stop all together until I release the brakes
Old Apr 21, 2005 | 09:16 PM
Default RE: Blinker lights stop working when brakes applied
Check your ground connections.
Is the car wired for a trailer?
Is only one side blinking fast?
Are any of the light bulbs burned out?
What happens when you turn the hazards on?
Old Apr 22, 2005 | 04:37 PM
nsmock's Avatar
Where are the grounds that would affect this?
It is not wired for a trailer.
It started as one side but is now affecting both sides.
On the dash it says there is a light burnt out however when I check all lights work.....
I have had two things happen 1. the hazards will not blink at all 2. the hazards will blink fine but will stop when I apply the brakes?
Thanks for any help you may be able to offer.
Old Apr 22, 2005 | 07:37 PM
There should be ground points bye the taillights.Check all the bulbs and sockets in the rear for corrosion.
Also check the plugs fro corrosion as well.
jesbarber
Jul 20, 2012 11:05 AM
mramend
Apr 19, 2011 11:52 PM
Vgatorgirl
Jul 23, 2010 09:27 AM
zloetakoe
Jun 21, 2010 04:40 PM
s80mike
May 17, 2005 10:28 AM
