Which o2 sensor do i need? here are the codes
Old Jan 25, 2009 | 02:08 PM
trussguy's Avatar
Default Which o2 sensor do i need? here are the codes
P0135
O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P0136
O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
Any help will be greatly appreciated!
Old Jan 25, 2009 | 06:15 PM
trussguy's Avatar
Default RE: Which o2 sensor do i need? here are the codes
nevermind...apparently bank 1 is before the CAT and bank 2 is after the CAT...
Old Jan 25, 2009 | 06:24 PM
Your car only has 1 bank. By those codes looks like both sensors are at fault.
The only cars that have 2 banks are the 6 cylinder motors.
Old Jan 25, 2009 | 07:22 PM
trussguy's Avatar
THanks again tech!
I was just wondering,
could it be a vacum leak and which hose or hoses should i check first? and what's the best way to check them?
Old Jan 25, 2009 | 07:40 PM
Yes it is possible it could be a vacuum leak.Best way to check is with it running spray around all hoses with Carb cleaner and listen for the idle to change.
Old Jan 25, 2009 | 08:32 PM
trussguy's Avatar
Ok I'll try that as well. Someone on another forum was saying to check the wires with an ohmmeter and that if it read highthat most likely the heater was burnt out and would need to be replaced. Im not a mechanic so i don't really know what "high" would be as far as reading the ohmmeter. Also what would you check first? the vacum or the resistance on the wires?
here's what they said...
"Check the wiring to the sensors, the heater malfunction on bank 1 indicates that the circuit to the heater wires is open or shorted. You can use an ohmmeter on the two white wires from the sensor and it should read low resistance. If the resistance is very high then the heater itself burned out and the only way to fix it is to replace the sensor. There really isn't enough information on that code to narrow it down.
There was a TSB on some years that added an extra length of wire to both sensors which doubles the number of connections that can go bad."
Does the car need to be running when i check the resistance on those wires?
I hate to be a pain.. everyone seems so helpful and i appreciate greatly
Old Jan 25, 2009 | 09:03 PM
Check the vacuum leaks first.
But usually when the heater circuit comes up I know the sensor is bad. I have never even tested a sensor like that I have just replaced them.
If you want you can test it. Car off and the sensor unplugged.
Also the comment about the extra plug I highly reccomend making sure it is inline if the car falls under it.
Old Jan 26, 2009 | 09:35 AM
trussguy's Avatar
what do u mean inline?
Old Jan 26, 2009 | 09:41 AM
There was a harness designed to go in between the engine harness and the O2 sensor. It was designed to stop the O2 from being contaminated. See the wires are basically hollow on the center air flows through the wires in the sensor and in the harness. After time oil would work its way in there and contaminate the sensor. The harness was designed to stop that from happening.
Old Dec 6, 2023 | 08:22 PM
DMacKay's Avatar
this is an old post, and old car..
Just want to add that a smoke test might provide some clarity for vacuum leaks.. since it hasn't been mentioned.
Also I'm wondering if you had found the solution?
squareface1
Mar 11, 2018 06:34 PM
musclegandalf
Jan 18, 2015 11:07 AM
ajwgator
Oct 4, 2010 09:50 AM
gilber33
Oct 19, 2009 07:01 PM
my_d3c3mb3r
Mar 24, 2006 09:30 PM
