Oil filter Cap Leak?
Old Feb 1, 2009 | 04:08 PM
TIPSP's Avatar
Got Boost?
Default Oil filter Cap Leak?
Hey guys and gals.
Just noticed the other day that the V70R has an oil leak. We changed the oil yesturday, and we have come to the conclusion that the oil filter cap is leaking at the top where the threads are, Like it is not sealing. Just have to get a new cap. Just wondering if any of the other owners experienced this type of leak?
Tech, do you see this happening frequently?
Old Feb 1, 2009 | 05:05 PM
Somthngfrce's Avatar
Old Feb 1, 2009 | 05:59 PM
JTapper's Avatar
Pull if off and make sure the o-ring is there, and seated properly and didn't bind up when you threaded it back on (I get a new o-ring included when I buy new filters). Also, when you reinstall the filter housing, put some clean oil all over the o-ring. This will keep it from binding up and seat nicely. Basically the same idea as with any oil filter.
Old Feb 1, 2009 | 11:14 PM
TIPSP's Avatar
Got Boost?
Yeah We did that, but on ours, it looks as if the cap itself, it is not circular. It looks like it melted, and it wont seal. It is weird, never had this happen before on any of the other cars. Well I will just get a new cap and call it a day .
Thanks for the reply
Old Feb 2, 2009 | 04:01 PM
JTapper's Avatar
Odd...They're made of a temp-resistant composite that shouldn't warp. Too bad since those housings aren't cheap. I've been debating on buying the volvo tool for removing them, since an oil filter wrench is nearly not an option. I found a hinged one I can angle the handle down and barely fit in there, but I always bust a knuckle doing it.
Old Feb 2, 2009 | 04:59 PM
TIPSP's Avatar
Got Boost?
Melted was not a good choice of words. Warpped it a better word for it.
I dont remember where my dad got the tool, but it makes the job so easy.
thanks!
Old Feb 2, 2009 | 09:30 PM
I have never seen that either.
angusjustice
Aug 30, 2010 12:03 PM
KarenLR
Aug 24, 2010 09:02 AM
Rdriver
Sep 25, 2008 11:04 PM
jeannelw
Nov 18, 2005 10:05 PM
Invictus84
Sep 3, 2005 06:35 PM
