Passenger Heated Seat
Old Jan 27, 2009 | 09:20 AM
cameron's Avatar
Default Passenger Heated Seat
Hi,
I have recently bought an 2003 V70 2.5 Turbo diesel on a 53 plate.
The passenger heated seat does not appear to be working.
When you push the switch for the passenger seat the two lights on the switch indicate the same as for the driver's seat but the seat does not heat - neither the base or the back rest.
Does anyone have any advice on the most likely cause of my fault, any methods of eliminating likely causes etc.?
Any help much appreciated,
Thanks,
Cameron
Old Jan 27, 2009 | 10:53 AM
Default RE: Passenger Heated Seat
I would take a peak under the seat and see if anything is unplugged.
Old Jan 27, 2009 | 11:24 AM
cameron's Avatar
Have already done that and there is nothing obviously unplugged.
Cameron
Old Jan 27, 2009 | 11:38 AM
The the Dealer or someone with a setup that can read the seat module will have to see if there is codes.
Old Nov 28, 2012 | 11:49 AM
Cornmuffin's Avatar
I have the same issue and had no luck myself. Already checked under the seats and the fuse as well. Fuse looked good. Bummed I can't fix it myself.
islandmanpa
Oct 24, 2006 09:07 PM
spinningcain
Mar 26, 2006 03:49 AM
Enzo
Feb 15, 2006 04:59 AM
cool_kyle_3000
Jan 4, 2006 05:58 PM
tony8169
Feb 2, 2005 12:07 PM
