radiator flush?
Old May 29, 2006 | 11:05 AM
cooter's Avatar
Default radiator flush?
in my owner's manual it says the coolant normally doesn't need drained. But mne is at the minumin mark level. Is it bad to drain and refill the cooling system? Also, do you refill it in the little plastic tank that sits on top of the engine? It is a 98 V70 non turbo.
Old May 29, 2006 | 11:42 AM
Default RE: radiator flush?
The coolant should be flushed about every 30,000 miles.
There is a drain in the bottom of the Radiator and one on the back of the engine. You could use either.
Yes you fill the Tank to fill the system. Tip if you do it fill the bottle all the way to the top then drive about 6 miles then check again you might have to add more then.
Old May 29, 2006 | 12:05 PM
cooter's Avatar
my owner's manual says to: 1. remove expansion tank cap
2. move temp. adjustment control to max. heat. open drain ***** at the rear left of the engine block and
at the bottom right corner of the radiator.
3. disconnect the lower radiator hose
To refill:
1. Close drain ***** and reconnect hose
2. fill expansion tank to the max mark or slightly above
3. run engine until hot. check the cooling system connections for tightness. recheck coolant level.
It doesn't tell how to flush the system?
It also says to ONLY use Volvo coolant, is this just because they want you to but their product?
Is the temp. adjustment control the one inside the car on dash controls?
Old May 29, 2006 | 12:36 PM
You can use any coolant you want.
You don't have to adjust the Temp.
Just drain and refill. That would be flushing. All of it drains out.
Old May 29, 2006 | 12:57 PM
cooter's Avatar
I have some Peak antifreeze that is 50/50 pre-mixed, it says add nothing just put in the cooling system and your ready. Ever used this, is it o.k.? I assume I should do this when the engine is cold?
Thanks
Old May 29, 2006 | 05:56 PM
That is fine and Yes install to a Cold car.
Old May 29, 2006 | 06:53 PM
cooter's Avatar
I am also going to attempt to replace the timing belt as well. Should I just do all this at the same time?
Old May 29, 2006 | 07:11 PM
I would .
Here is a link that might help with the Belt.
http://www.babcox.com/editorial/ic/ic60326.htm
patrm
2001-2013 model year V70
23
Mar 5, 2014 08:43 PM
shop2
Nov 1, 2011 08:56 AM
endlessct9a
Oct 9, 2008 07:53 AM
Glenn B
Feb 19, 2008 04:57 PM
JCVolvoS80
Jun 17, 2005 01:49 PM
