Radiator replacement
Hello all.
I think i bit off more than I bargained for. My V70XC has 254K miles and the radiator started to leak. I picked up one at IPD (quick responce and shipping) anyway, I started to remove the front end of the car to get at the radiator to remove. First mistake. After removing most of the grill, I find out that I cannot either pull it up and out or drop it down. So to cut to the chase, has any body else replaced their radiator or at least tried to? I want to stay away from the dealer $$$$$$$$$$$$ Any input is more that welcome at this time..... Volvo for Life,, but not my life savings....... Gary |
Radiator Replaced
Well it's done. I took some time to look thru some posts and found a good reference to the radiator on VOLVOSPEED.COM. Bay 13.
Thanks for all the feedback... |
Just curious, did you do it from underneath or from the top ??:confused:
the radiator replacement is done from the bottom.
I was just curious as I've seen posts where they've done it from the top and say it's easier.
I have to do mine soon. |
If that was the first radiator replacement on it, congrats! I'd believed none of them made it that far, 245k miles. Mine cracked out at around 175k.
I would doubt it's the original but it's possible. I have a bleed from engine oil to coolant. I'm living on borrowed time as I know it's leaking, I have a radiator and I just can't make the time to drop it in. If it opens up and gets into the oil pan I'm going to be screwed. I put my sport springs in yesterday so I guess this weekend maybe ??
I've never been a fan of the plastic aluminum crimped radiators but the Mfg's aren't going to change. They are too easy and cheap to make. :( |
