Radiator replacement
Old May 5, 2010 | 06:44 PM
basha53's Avatar
Default Radiator replacement
Hello all.
I think i bit off more than I bargained for. My V70XC has 254K miles and the radiator started to leak. I picked up one at IPD (quick responce and shipping) anyway, I started to remove the front end of the car to get at the radiator to remove. First mistake.
After removing most of the grill, I find out that I cannot either pull it up and out or drop it down. So to cut to the chase, has any body else replaced their radiator or at least tried to? I want to stay away from the dealer $$$$$$$$$$$$
Any input is more that welcome at this time.....
Volvo for Life,, but not my life savings.......
Gary
Old May 8, 2010 | 05:50 AM
basha53's Avatar
Default Radiator Replaced
Well it's done. I took some time to look thru some posts and found a good reference to the radiator on VOLVOSPEED.COM. Bay 13.
Thanks for all the feedback...
Old Nov 20, 2011 | 10:53 PM
Just curious, did you do it from underneath or from the top ??
Old Nov 21, 2011 | 08:23 AM
jda2000's Avatar
the radiator replacement is done from the bottom.
Old Nov 21, 2011 | 03:32 PM
I was just curious as I've seen posts where they've done it from the top and say it's easier.
I have to do mine soon.
Old Nov 22, 2011 | 09:38 AM
bulldog's Avatar
If that was the first radiator replacement on it, congrats! I'd believed none of them made it that far, 245k miles. Mine cracked out at around 175k.
Old Nov 22, 2011 | 01:24 PM
I would doubt it's the original but it's possible. I have a bleed from engine oil to coolant. I'm living on borrowed time as I know it's leaking, I have a radiator and I just can't make the time to drop it in. If it opens up and gets into the oil pan I'm going to be screwed. I put my sport springs in yesterday so I guess this weekend maybe ??
I've never been a fan of the plastic aluminum crimped radiators but the Mfg's aren't going to change. They are too easy and cheap to make.
Old Jun 26, 2013 | 07:37 PM
mikeawd850
Nov 30, 2012 02:26 AM
jcmartin
Oct 6, 2008 08:48 AM
spioana007
Dec 13, 2007 06:13 PM
Pepper
Nov 9, 2007 06:37 PM
mikkowus
Jul 25, 2007 04:56 PM
