Replace inner tie rod boot?
Old Jun 18, 2009 | 11:42 PM
sporky's Avatar
Default Replace inner tie rod boot?
I'm going to perform a small overhaul of my suspension/steering including replacing the outer tie rod ends. When the outer ends are removed, will I have easy access to replace the inner boots? Also, does the inner tie rod joint need to be re-packed with grease, or do I need only to replace the boot? thanks
Old Jun 19, 2009 | 03:52 AM
rallyracer's Avatar
yes, the boot will slide right off. no, you don't grease the inners. just replace them too so you don't have to do the whole job and alignment over later.
Old Jun 19, 2009 | 08:29 AM
sporky's Avatar
cool...thanks!
austinbrady
Aug 19, 2011 06:06 PM
pc142
Jun 3, 2011 07:45 AM
go2sharks
Feb 25, 2007 12:08 AM
tcrossley
Jan 24, 2007 08:48 PM
knight rider
Jun 9, 2005 08:45 PM
