self leveling suspension, 98 V70?
Old Dec 11, 2011 | 12:20 PM
iceracer46's Avatar
Default self leveling suspension, 98 V70?
I have to order new rear shock mounts, because that thumping I hear in the back is from the broken shock mounts!
I see there are mounts for cars that have self leveling suspension. How do I determine if mine has that feature?
Thanks, Terry
Old Dec 11, 2011 | 04:37 PM
stage2c70's Avatar
Try calling a dealership and get them to decode your vin # . They will be able to tell you your suspension option.
Old Dec 11, 2011 | 08:24 PM
iceracer46's Avatar
Thanks for the idea.
I also have been perusing the part images and it appears, at least by the images I see that the self leveling shock mounts have 3 bolt mounting instead of 2 like mine has.
I've been driving the car thinking all along that the spring seats were the source of the noise.
The broken mounts are also the likely source of the bouncing and oscillation I have been experiencing, from the rear because the shocks are effectively disconnected.....D'oh!
Old Dec 14, 2011 | 07:42 AM
S70driver's Avatar
I believe only the AWD models had the self leveling.
Old Dec 18, 2011 | 08:09 AM
JRL's Avatar
JRL
Not true
Some FWD 98 V70s came with Nivomats (I had one)
The bottom line on your VIN plate on the left inner fender is the CHASSIS CODE, give that to your dealer
...and consider new rear shocks, you will be amazed at the difference!!
Standard rear shocks are pretty cheap and the labor is the same as they need to come out anyway for new mounts
Old Dec 19, 2011 | 10:14 AM
bulldog's Avatar
Did ALL awd xc 70's come with self-leveling suspensions?
Old Dec 20, 2011 | 03:46 PM
JRL's Avatar
JRL
In the US, yes
Not sure about around the world cars
jollygoodgold
Mar 22, 2013 08:34 PM
sean177
Jul 1, 2010 03:21 PM
pinocs
Sep 2, 2008 09:56 PM
flyer1
Sep 17, 2006 01:07 PM
y2blade
Suspension
Oct 23, 2005 03:54 PM
