shudder only when wheels are turned
Old Aug 3, 2008 | 05:53 PM
Buck's Avatar
Default shudder only when wheels are turned
98 V-70 T-5 I have a shudder at 1-2 shift only when the wheels are turned. When they are straight it shifts fine. Anybody have any ideas? thanks in advance
Old Aug 4, 2008 | 06:27 PM
Default RE: shudder only when wheels are turned
How do the axles look?
Old Aug 4, 2008 | 06:38 PM
Buck's Avatar
Thanks Tech, The boots look good. It had a motor mount replacement just before I got. It was the front one. I'm wondering if the axle could be bent.
Old Aug 4, 2008 | 07:04 PM
I would check for play in the inner joints on both axles.
Old Aug 4, 2008 | 07:14 PM
Buck's Avatar
Thanks Tech. I might just change out one axle at a time. It's not all that expensive and I can do it myself. Thanks again
Old Aug 4, 2008 | 07:27 PM
I would check them first.
Old Aug 21, 2008 | 06:33 PM
Buck's Avatar
I've been paying special attention to this shudder. It only does it when I accelerate slowly. On fast acceleration it shifts just fine.It feels alot like a pump has low pressureor a filter is clogged and it spurts fluid on every rotation. Does this car have a filter? The fluid is clean and smells normal. Thanks in advanve
Old Aug 21, 2008 | 09:34 PM
No it doesn't have a filter you can change. Does the fluid look dirty?
Old Aug 22, 2008 | 12:27 AM
samadkins29's Avatar
Does it do it when in reverse? *just gonna throw that in*
Old Aug 22, 2008 | 08:57 AM
Buck's Avatar
No the fluid is clean and smells good. It really feels like the pump is starving for fluid. I feel it in the gas pedal when it shudders like the engine is rolling back and forth as well.
Old Aug 22, 2008 | 11:55 AM
How about the transmission torque mount is that ok?
Old Aug 22, 2008 | 12:24 PM
Buck's Avatar
Thanks for your response, I'm not sure where the transmission torque mount is. Can you tell me more. I know it had a new lower motor mount installed before I got it.
Old Aug 22, 2008 | 02:32 PM
There is a mount that goes between the transmission and the subframe. If you look under the car it is by where the one power steering line goes from the subframe to the rack.
Old Sep 17, 2008 | 06:46 PM
Buck's Avatar
Well, After all the concern for the transmission it turns out that the front and rear motor mounts were bad. I changed them out and no more shudder and it runs so smooth now. Thanks for all the help. I sure learned alot with this one.
Old Sep 17, 2008 | 07:11 PM
Glad all is well.
poor_red_neck
Nov 30, 2009 01:39 PM
Royalty
Aug 31, 2009 09:56 PM
Buck
Jul 22, 2008 07:44 PM
