Is there a pin adapter for gauge clusters
Old Nov 21, 2019 | 08:44 AM
Reese Handley's Avatar
Default Is there a pin adapter for gauge clusters
Found a s80 with the style of the T5 cluster, was wondering if it would fit into my V70 and if there was an adapter for it.
Old Jan 6, 2020 | 08:02 PM
matt01's Avatar
The only way to swap clusters successfully is to get one from (usually) the exact same model year AND the same part Numbers. On the top of the DIM there's a white label, somewhere on that label you'll see "YZK P/NO 69294-620T" or something like that. Thats the number off my 02 V70, If you can find a cluster matching the "620T" it should technically work.
All the 2001's and 2003 model years I looked at did not have the correct part numbers for my car.
However it will show the mileage of the donor car if it is higher than yours.
Now, taking apart the 2 clusters and swapping gauge faces is a whole other deal, you'll have to pull them apart and take the needles off, Im not sure exactly how to do that, but I think there's write ups around somewhere.
AnEskimo
Jun 25, 2019 06:04 AM
Rawbertd
Mar 14, 2013 02:51 PM
hayleyspop
Jul 6, 2012 10:22 AM
elbows8
Apr 23, 2008 11:12 PM
cool_kyle_3000
Jun 28, 2006 12:08 AM
