Throttle Body
Old Oct 18, 2011 | 07:50 PM
JTG's Avatar
JTG
Default Throttle Body
Hi,
99 V-70. Non turbo. 126.000 miles. Daughters 1st car.
Throttle Body I believe is junk. It is emitting a high pitched whine sound after shutoff, and idles like it is misfiring. Going to dealer to double check diag.
I found a place to buy A throttle body. I do not know the "bore" size and plenty of TB's to choose from. Does anyone have any advice on what "bore" size to buy? 52mm, 54mm, 58mm, 70mm?
Question is the r&r looks straight forward. A couple of quick connect electrials, a hose clamp and four bolts. Any recommendations for this r&r? Do I use any sealant on the TB gasket? If so any kind? Any threadlock on the bolts? Will the ECM have to be flashed-set after I r&r the Throttle Body at the Dealer?
Thank you for your responses. BTW here is the website I found to buy the parts. http://www.swedishpartswholesale.com...l:1))&Vi=11879 4294963744 1733&mk=Volvo&md=V70&y=1999&No=0&Npp=10
JTG
Old Oct 18, 2011 | 10:34 PM
The ETC on these cars go out a lot. Read a little in the S70 section and you'll see what most guys recommend here.
Old Oct 19, 2011 | 06:43 AM
JTG's Avatar
JTG
Thank you for response. I looked in that section and searched for it and was unable to find it. Do you know what "bore" size I should use? Is the r&r straight forward?
thx
JTG
Old Oct 19, 2011 | 10:53 PM
Sure don't.
https://volvoforums.com/forum/volvo-...70-gulp-57407/
Old Oct 20, 2011 | 08:18 AM
JTG's Avatar
JTG
Not many mechanics on this Site/Actual Techs?> My Jag forum if I put a question up I get 10 responses in a day. I always thought that Volvo's had a following?
Nobody knows the bore size I should buy? http://www.swedishpartswholesale.com...l:1))&Vi=11879 4294963744 1733&mk=Volvo&md=V70&y=1999&No=0&Npp=10
Old Oct 20, 2011 | 02:02 PM
From time to time the mechanics come on, just depends on what's going on in their life at the time. I didn't try the link but I think it's broken.
Old Oct 20, 2011 | 02:35 PM
JTG's Avatar
JTG
I hear yah. I will go and pay ask.com etc to get the answer. thanks
MFHull
Oct 9, 2014 09:01 AM
treestone27
Apr 29, 2014 07:40 AM
go2sharks
Jan 21, 2009 10:24 PM
proudmonkey
Jul 21, 2005 10:01 PM
wavewright
Apr 9, 2005 06:15 PM
