Tilt sensor
The dealership initially called it a tilt speed sensor, but replaced two Yaw Rate Sensors - Part # 8622413-6, cleared codes and calibrated DSTC.
Car is still cutting off at low speeds - once while cornering; once when pulling into driveway
93,000 miles - spark plugs and filters recently replaced. Had throttle body code at that time - dealer says there is no throttle body code.
