Tilt/Telescopic Steering Wheel
Old Jan 24, 2006 | 05:52 PM
B1mmer's Avatar
Default Tilt/Telescopic Steering Wheel
My '94 Turbo Wagon has a Tilt/Telescopic steering wheel, as I would expect all 850's do. The thing with mine is that it doesn't lock into place very securely. I can release it, set it to a position, but when I 'lock' it, it doesn't seem to lock with enough pressure. If I pull on the wheel with minimal effort I can pull it in and out. Is there a cable that can be adjusted on the tilt/telescopic lock that will give it a better hold? Thanks in advance. - AB
Old Jan 24, 2006 | 10:26 PM
Default RE: Tilt/Telescopic Steering Wheel
Pull the steering wheel covers off and inspect the handle for cranks. You might also be able to reposition it.
Old Jan 25, 2006 | 05:15 PM
B1mmer's Avatar
ORIGINAL: tech
I assume that you're talking about removing the cover for the steering column and inspect the handle for 'cracks'. Can you confirm? Thanks - AB
Old Jan 25, 2006 | 08:58 PM
Yes there is 2 t-25 screws and 2 T-15 screws to get the covers off.
Old Feb 24, 2010 | 03:38 PM
stnwgnya's Avatar
By steering wheel cover do you mean that panel beneath the steering wheel by your knees?
Old Feb 24, 2010 | 09:06 PM
No the 2 plastic covers around the column. Like covering the wiper switch and turn signal switch.
Old Feb 25, 2010 | 11:59 AM
stnwgnya's Avatar
awesome, i'll check it out next weekend when i have time. I have the same problem. I was putting on a rubber steering wheel cover, and it was so tight that when i pulled down on the steering wheel i think i stripped the locking/tightening mechanism. I have a block of wood holding the steering wheel up now. .
taylormaed
Feb 13, 2013 08:05 AM
Newport_j
Aug 3, 2012 08:22 PM
retired teach
Apr 11, 2012 08:46 PM
cool_kyle_3000
Jun 30, 2006 12:26 AM
mo t5
Jan 25, 2006 08:35 PM
