timing belt cover bolt?
Old Oct 15, 2009 | 01:25 PM
iceracer46's Avatar
Default timing belt cover bolt?
stupid me recalled reading something that said; "checking the belt is easy, just one bolt holds the cover on" or words to that effect. I just took the single bolt I saw on my 98 v70.
It was a long shoulder bolt on the side upper in the centre of the cover. 12mm socket.
Was this a bad thing to do? will I be able to pry the top open to get a look at the timing belt this way?
Thanks, Terry
Old Oct 15, 2009 | 07:41 PM
The cover should slide up now then you should be able to lift the top section up and inspect the belt.
tobolate
Oct 13, 2011 12:24 PM
Counselor828
Aug 22, 2011 12:19 PM
Steve_F
Aug 7, 2011 07:08 PM
dads 740 turbo
Nov 6, 2008 07:50 AM
colgate41
Nov 15, 2007 03:46 PM
