totally confused headlamps
i am having an extremely difficult time getting the right side lamp assemble to be proper brightness. first i added new silverstar elements. the right side is yellowy dimmer than left
i also checked the voltage between both sides...identical. then for giggles i found the ground at the bulb and added an extra ground thinking it was not as bright due to poor ground.
what am i missing? is the relay for headlamps wired for each side separately? is there a ground i am missing for the entire right assembly?
also note, i completely replaced the entire housing with a new clean glass assembly..
help!!!!
Robin
help!!!!
Robin
RobCoop
1998-2000 model year V70
02-22-2014 07:28 AM
neveradullmoment
09-06-2009 08:33 AM
