Tranny flushed again, Added lubeguard.
Old Dec 1, 2007 | 02:37 AM
v70 2.4t's Avatar
Default Tranny flushed again, Added lubeguard.
Hi guys, I had my tranny flushed again, tranny was starting with the old 3-4 flair, flushed with toyota T4 fluid JWS-3309, as used by volvo.
This time the Tranny shop added lubeguard, your thought's on this product????
3-4 flair has now stopped even in hot traffic conditions when it was at it worst.
I know that alot of people have the same issues as i do, so maybe this could be an extension to the life of trannys that are starting to play up, i dont think it would do much for tranny's that are too damaged, but if it gets me through another year i'll be happy i kept the $$$$$ in my pocket rather than fork out for a new tranny.
Don't know how the lubeguard will perform but thats the only thing that the tranny shop would add.
goodluck
v70 2.4t
Old Dec 1, 2007 | 11:05 PM
Rickc10ny's Avatar
Default RE: Tranny flushed again, Added lubeguard.
I had a rough 3/4 shift on a 93 Benz automatic, The local Mercedes guru said to try Lubeguard ATF protectant first, if that didn't work he said to bring a check good for $4K . The Lubeguard worked .The shift problem cleared up in about 50 miles and I drove the car another 15K trouble free.
The Volvo shop I take my S70 to recommends Lubeguard on all of it's ATF flushes
Old Dec 2, 2007 | 12:06 AM
01_fast_ride's Avatar
This is good news. Great tip.
Old Dec 3, 2007 | 01:10 AM
v70 2.4t's Avatar
Yes i thought so too, i'll wait 2-3 months i suppose until i will know for sure, but the quick fix suits me for now.
good luck
v70 2.4t
Old Apr 13, 2008 | 02:30 PM
uncle's Avatar
How's the tranny holding up with the lubeguard? Has anyone tried the Auto-RX transmission cleaner?
Old Apr 13, 2008 | 04:06 PM
v70 2.4t's Avatar
No problem at all, no flair at all, i will flush each year and add lubeguard.
just went through summer without any issue's, the real test will be when its been in there for 20K
or so i'll keep you all posted on the out come.
good luck
v70 2.4t
Old Apr 27, 2008 | 06:53 PM
cody's Avatar
Why did you use Toyota t4 ? Is this the same as the volvo ATF? and the lubeguard you used who makes it? I need to flush my tranny. My mechanic wants to get the volvo ATF at $200.00 (I live in Durham Ontario Canada) and I have been reading up on the Volvo ATF debate. I don't know if I can get mobil 3309 and if I can what it will cost. Also Esso makes 3309 is it compatable? This Toyota T4 JWS 3309 I assume I can get from Toyota. Did you use this to flush the system and replace with Volvo ATF? Thank you in advance
Old Apr 28, 2008 | 03:17 AM
v70 2.4t's Avatar
Cody,
I used t4 because it's the same as the volvo ATF, just much cheaper to buy from toyota.
I called Mobil Australia and confirmed that it was the same fluid Volvo use,
Volvo don't make the ATF, it's made by Mobil for asian warner transmissions.
So i flushed the system and filled with Toyota T4 ATF.
I have now flushed twice with T4 i have had no issues with the fluid.
I have added lubeguard this time and it seems to be running fine.
no issues yet and about 10k km since last flush.
Check out the link below, it should help.
http://www.mobil.com/USA-English/Lub...l_ATF_3309.asp
good luck
v70 2.4t
Old Apr 28, 2008 | 06:13 PM
cody's Avatar
Who makes lubeguard? Thank-you in advance
Old Apr 28, 2008 | 06:20 PM
cody's Avatar
I called Toyota and the are 7.34/ litre VS Volvo $$$$$$$26.00/litre. I can get a 200 litre drum of mobil at 4.34/litre but unable to get in single litre containers and that is from a mobil dealer. Maybe my mechanic would buy and sell back to customers I don't know.
Old May 5, 2008 | 06:01 PM
faboV70's Avatar
I flushed the tranny on my 2001 v70t5 200 miles ago with toyota t4 fluid (using the flushing instructions "tech" postedon this site). proceedure was clean and easy.so far no problems with t4.
"tech," other respondents of this forum-I SALUTE YOU!
-fabo
Old May 5, 2008 | 10:59 PM
howardc64's Avatar
http://www.lubegard.com/automotive/t..._platinum.html
I put AMSOIL synth ATF in my 01 V70 T5 auto tranny once. It had some hard shifts. I guess it wasn't 3309 compatible. I put this Lubegard product in and it shifted a lot better.
Didn't get rid of all the problems tho so I switched back to 3309 and all is fine now.
From everything I've read, this is good stuff.
Also the B4 servo cover suppose to improve some of the 3-4 shift problems. You might check this out
http://www.volvoxc.com/resources/how...ervo-cover.pdf
Old May 5, 2008 | 11:30 PM
djerikd's Avatar
ORIGINAL: cody
Is that USD $? I just bought 16 quarts of Toyota T-IV over the last weekend. The invoice shows the list price as $7.13/quart, but I only paid $4.38/quart. It was certainly easier than buying the 3303 online, or paying the high price at the Volvo dealer.
Old May 6, 2008 | 09:54 PM
cody's Avatar
That was canadian $$
Old May 7, 2008 | 03:05 PM
2002v70's Avatar
Amsoil ATF is J3309 rated. I use it in my '04 Toyota Sienna and will put it in my V70 soon. At least this stuff is synthetic and flows at -20'C in the winter. The Mobil (Volvo, Toyota etc.) is not.
Old May 9, 2008 | 11:19 AM
howardc64's Avatar
I see AMSOIL synth ATF is 3309 rated. All I can tell you is that I flush it with this, had shift problems, change it out with Mobil 3309 and shift problems are gone. I did this about 2 years ago tho, not sure if they changed the fluid.
It is synth and is def good stuff. From everything I've read, the key is the right friction index of the fluid.
Old Aug 26, 2008 | 04:32 AM
  #17
uncle's Avatar
Hows Your tranny going?
I've been OS for 4 months so my car will be needing a service and a flush when i get home to Sydney tomorrow and am going to add the Lubeguard. Where did you buy your Lubeguard from? Was it Platinum?
Old Aug 26, 2008 | 09:03 PM
  #18
McBain's Avatar
I used Lubeguard on my 95 Impala SS. Up until 125,000 miles I changed the fluid every 25,000 miles. The last time I changed it (@ 125,000) was with Mobil 1 tranny fluid and Lubeguard. I sold the vehicle last year with over 280,000 miles with the original transmission and no rebuilds. When I flush my V70 in a couple of weeks I will be putting Lubeguard in.
Old Aug 28, 2008 | 04:06 AM
  #19
v70 2.4t's Avatar
Uncle,
All good with the tranny, Ive done about 12,000km since the last flush.
No harsh shifting, very Slight jerking from time to time...but nothing major.
Good luck
v70 2.4t
Old Aug 28, 2008 | 05:22 PM
  #20
uncle's Avatar
Where did you buy your lubeguard? I can't seem to find it anywhere in Sydney.
