Transmission chirp/sqeak
Old May 7, 2011 | 04:02 PM
Fly00's Avatar
Default Transmission chirp/sqeak
I have a strange sound coming from the left side on the trans/engine compartment when I let off the gas or get back on the gas. I sounds like a chirp or sqeak and only does it once for a split second. If the car is idleing and I shift from rev to drive with my foot on the brake it will make the sound as well.
Old May 9, 2011 | 05:10 AM
VTBricked's Avatar
Maybe mount, but it's an odd noise for a mount. Have someone look at the engine while someone else shifts it - maybe you can see the source with your eyes and ears.
Old May 9, 2011 | 09:45 AM
Georgeandkira's Avatar
Default Try this
Hello, Start your car and make it do the chirp/squeek using the "foot on the brake R to D" method. Do this to be certain your car is making the noise. Shut her off and relieve the serpentine belt by loosening the tensioner and looping the belt off. Start the car and try it. Be quick about it if the engine has warmed up fully. Kira
Old May 15, 2011 | 12:03 AM
J98s70t5's Avatar
it might be your belt i know its on the opposite side but mine dose it as well and it sounds like the same problem
titaniums6025t
Jul 26, 2016 01:51 PM
Stephen0523
Mar 5, 2015 02:22 PM
sktrmoss
Mar 11, 2011 08:53 AM
zerochills
Mar 8, 2011 07:59 PM
zerochills
Dec 20, 2007 06:44 AM
