Trunk key cap
Old Sep 6, 2011 | 07:29 PM
thatsnotavolvO's Avatar
Default Trunk key cap
I just bought a used 2000 V70 and it has some issues as would be expected in a used car. One is the trunk keyless entry is finicky. I see that others have this problem but honestly I just don't care about the auto lock. That is of course if I could use my key. There is a spot on the trunk that looks like a key should go in but it has a black plastic solid circle thing instead. Is this a cap that can be removed for the key to go in? If so how do I? If not, is there a possible place to use a key in the trunk?
Old Sep 6, 2011 | 10:20 PM
The little cap on mine flips down.
Old Sep 7, 2011 | 07:37 AM
The cap I'm refering to is under the flip piece. At least I know that's where the key should go.
Old Sep 7, 2011 | 09:08 AM
Maybe the deal on the inside of the cap is stuck to the key hole. Try to scrape of peal it off. A pic might help.
Old Sep 7, 2011 | 04:08 PM
thanks for the help. turns out the lock was ruined and the prev. owner had it plugged. grrr. this means i have to either get the mechanism for the keyless remote fixed or the cylinder rebuilt for my key.
Old Sep 7, 2011 | 05:04 PM
Georgeandkira's Avatar
Hello, If the cylinder can be repinned, which I assume is the case, it should be vastly cheaper than any "new part" purchase. Removing it will be the hardest part. Kira
Ryan911t
Apr 13, 2014 10:19 PM
Mie518
Apr 30, 2011 02:49 PM
jbohrer60
Jan 28, 2010 12:15 PM
tonyfolenta
Jan 26, 2010 06:20 AM
Vincef
Mar 18, 2009 08:42 PM
