V-70 t-5 struts, shocks, anti-sway bar
Old Aug 31, 2005 | 08:21 PM
ray hummell's Avatar
Default V-70 t-5 struts, shocks, anti-sway bar
I have a 1998 v-70, t-5 with sports suspension (dynamic chassis). I am ready to replace the shocks, struts, and anti-sway bars. I am interested in using Bilstein HD struts and shocks and IPD heavy duty (25mm) anti-sway bars. Does anyone have experience with this combination or another heavy duty combination? I am interested in knowing how much the ride might deteriorate and how much the handling/cornering will improve. I also have a "clunking" sound coming from the right front - it is the spring seats...I understand that this is a common problem and a $400 repair at the dealer. Oh well... Ray Hummell, San Diego, CA
Old Aug 31, 2005 | 09:45 PM
Default RE: V-70 t-5 struts, shocks, anti-sway bar
You can check and see if it is the spring seat very easy.Get a 13/16 Wrench and try to turn the nut for the strut.If it turns easy it is bad.It should feel rubbery and not turn.
Old Sep 22, 2005 | 10:09 PM
andrewgrhogg's Avatar
I had the same clunking sound. Do the spring hats yourself - took me 1 hour 40 mins fo rth first one and 1 hour for the second. You will need a jack, two jack stands and a set of good spring compressors, all of whihc willcost you less than $400.
Old Sep 30, 2005 | 12:33 PM
Carlos's Avatar
Hello I am new to the Forum. Is the spring seat the same as the spring hat, are they synonymous? Or is the spring hat the strut mount? Thanks for your help.
Old Sep 30, 2005 | 09:22 PM
ORIGINAL: Carlos
I think they are all the same thing just called different names by alot of people.
Rambler875
Aug 23, 2012 07:23 PM
derPanzer
May 1, 2012 03:06 PM
Sweet T5R
Mar 29, 2012 11:41 AM
Volvo240Rookie
Oct 7, 2010 04:20 PM
euro3b
Dec 18, 2007 02:40 PM
