V70 Clutch
Hi to all - new member here.
I've got a V70, 2.5T 5 cylinder. Goes really well (and don't seem to have any noises so far!!). I have a been losing a little bit of brake fluid recently (about max to min in two weeks). I've now worked out, having spent a lot of time looking at brake lines that the pot feeds both brakes and clutch. I am happy that there is no leak on the brakes. I have also had a slight problem with the clutch pedal not returning but hadn't made the connection. I think it must be the seals on the slave cylinder for the clutch and I have found fluid in the area. So the £1,000 question is how do I change the things???
Any help would be appreciated as I do not want to be ripped off by the local dealer if at all avoidable.
Thanks for your help,
Jon
Jon
gentlejax2
06-18-2012 03:19 PM
rrolsbe
09-26-2010 08:22 PM
93 850 Non turbo - New clutch installed but doesnt work. Problem with hydraulic system / clutch fork
Dreas
12-07-2008 11:41 PM
